Re: pic: Bit Buckets 2015 Prototype Drive Pod
But the team probably wouldn't have the heart. |
Why geared so fast?
Why not both? Never give up the mill.... |
I would take the mill home.
![]() We might get rid of our old Grizzly lathe in favor of something that can actually cut steel in a few months, so a hobby machine might be coming my way already... |
We're using Killough drive, so robot speed is 1/sqrt(2) wheel speed. We also like the simplicity of a single reduction gearbox.
I'm not certain; I think 60 or 75 W. |
Neat drive module. I like the single reduction, very simple. What sort of fasteners are you using to tie everything together?
http://i.imgur.com/QCryxlE.jpg https://www.youtube.com/watch?v=2HHVwJ_C31M The side-panels took less than 2 min each to cut from 0.032 5052 Al. http://i.imgur.com/gU6AhRa.jpg Or a 4'x4' CNC router? All of these parts together took about 17min of cut time, most of which was in the pocketing. http://i.imgur.com/FgtZxiL.jpg Last edited by JamesCH95 : 15-01-2015 at 09:40. |
Exactly what wood are you burning with your laser. I say exactly because I have access to a 160 watt laser and have tried cutting 1/4 Baltic birch and if it will cut depends on where I get it.
Some cuts real nice and some will only seem to cut to the glue line then just starts burning. So, if you have any details on what you are using it would be appreciated. Thanks |
Yes it will cut an inch of pine but not some plywoods.
I think a killough actually has a root2 speed up.
#10
I hadn't put much thought into it, but I believe you are correct. Those modules will probably need another reduction stage.
#11
.25" 5-ply Baltic Birch plyood from Woodworkers Source. |
#12
#13
![]() Last edited by Dunngeon : 16-01-2015 at 01:38. |
#14
I'm not sure; the settings for our laser aren't "real" units like Watts or Inches/ second. I'd suggest you just try different settings until you find something that works. But do try it; the laser is an amazing resource to have available.
#15
Most laser cutters are different. If you want know the setting you can figure them out. But a good starting point is the internet and research into the laser cutter you have.
