Go to Post Here's some food for thought: Does your FRC program need the students, or do the students need your FRC program? - sanddrag [more]
Unread 15-01-2015, 09:31
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Bit Buckets 2015 Prototype Drive Pod
Neat drive module. I like the single reduction, very simple. What sort of fasteners are you using to tie everything together?
Originally Posted by orangemoore View Post
Well, that is assuming no one else has access to a laser cutter.
Cough Cough
Originally Posted by z_beeblebrox View Post
Our off-season chassis took about 4 hours of laser time, including setup. This module took 9 minutes.
It's a pretty neat tool to have; we can make 2D parts faster than literally any other team.
Edit: At least as fast as any other team.
Does a 4'x8' CNC plasma cutter count? Each of these parts took 4-5 minutes of cut time (1/4in 6061 T6), and that long cut time is due to the dozens of pierces for the lightening pattern.
http://i.imgur.com/QCryxlE.jpg
https://www.youtube.com/watch?v=2HHVwJ_C31M
The side-panels took less than 2 min each to cut from 0.032 5052 Al.
http://i.imgur.com/gU6AhRa.jpg
Or a 4'x4' CNC router? All of these parts together took about 17min of cut time, most of which was in the pocketing.
http://i.imgur.com/FgtZxiL.jpg
Unread 15-01-2015, 10:42
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Exactly what wood are you burning with your laser. I say exactly because I have access to a 160 watt laser and have tried cutting 1/4 Baltic birch and if it will cut depends on where I get it.
Some cuts real nice and some will only seem to cut to the glue line then just starts burning. So, if you have any details on what you are using it would be appreciated.
Thanks
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 15-01-2015, 13:20
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Thanks
Some plywoods have glues or fillers that don't cut well, which would explain it. 160W is otherwise overkill for 1/4" plywood.
Unread 15-01-2015, 13:40
Bruceb's Avatar
Yes it will cut an inch of pine but not some plywoods.
