Go to Post Thank you from the bottom of our IFI controllers, The Robonauts. - Natchez [more]
Unread 15-01-2015, 10:47
Re: pic: Bit Buckets 2015 Prototype Drive Pod
Originally Posted by z_beeblebrox View Post
We're using Killough drive, so robot speed is 1/sqrt(2) wheel speed. We also like the simplicity of a single reduction gearbox.
I'm not certain; I think 60 or 75 W.
I think a killough actually has a root2 speed up.
Unread 15-01-2015, 12:14
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I hadn't put much thought into it, but I believe you are correct. Those modules will probably need another reduction stage.
Unread 15-01-2015, 14:06
z_beeblebrox's Avatar
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Likely true. I'll look into it today.
Originally Posted by Bruceb View Post
Exactly what wood are you burning with your laser.
.25" 5-ply Baltic Birch plyood from Woodworkers Source.
Unread 15-01-2015, 23:27
Custom User Title
AKA: Cal
Version 2, ready to be cut tomorrow. Two stages of reduction, for an adjusted robot speed of ~10 fps. Adding a reduction stage only made it ~.25" longer and wider.
Our mostly complete chassis. This will also (hopefully) be cut out tomorrow.
Unread 16-01-2015, 01:36
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
What settings does your team use for the cut? I just realized we have a 60W 30x15 laser cutter sitting in the other room at school.
(2015-?): 973
(2012-2015): 955
Unread 16-01-2015, 08:44
Custom User Title
AKA: Cal
I'm not sure; the settings for our laser aren't "real" units like Watts or Inches/ second. I'd suggest you just try different settings until you find something that works. But do try it; the laser is an amazing resource to have available.
Unread 16-01-2015, 08:55
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Most laser cutters are different. If you want know the setting you can figure them out. But a good starting point is the internet and research into the laser cutter you have.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 16-01-2015, 11:38
Pumped
AKA: Ryan
Definitely, I wasn't trying to just copy paste settings. That rarely works in my experience. I was curious about the speeds you're able to go. Although if the laser doesn't use real units that's disapointing .
(2015-?): 973
(2012-2015): 955
Unread 15-01-2015, 23:44
BHS_STopping's Avatar
BHS_STopping BHS_STopping is offline
The Freshman
BHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant future
I'm just taking the conservation of energy route.
Assume constant power output P. P = force * velocity (dot product used here). Since the force of the wheel along the direction of motion is effectively reduced by a factor of 1/sqrt(2), the velocity must increase by a factor of sqrt(2) to maintain that power output.
[/The Freshman]
