Re: pic: Bit Buckets 2015 Prototype Drive Pod
I hadn't put much thought into it, but I believe you are correct. Those modules will probably need another reduction stage.
.25" 5-ply Baltic Birch plyood from Woodworkers Source. |
![]() Last edited by Dunngeon : 16-01-2015 at 01:38. |
I'm not sure; the settings for our laser aren't "real" units like Watts or Inches/ second. I'd suggest you just try different settings until you find something that works. But do try it; the laser is an amazing resource to have available.
Most laser cutters are different. If you want know the setting you can figure them out. But a good starting point is the internet and research into the laser cutter you have.
Definitely, I wasn't trying to just copy paste settings. That rarely works in my experience. I was curious about the speeds you're able to go. Although if the laser doesn't use real units that's disapointing .
Assume constant power output P. P = force * velocity (dot product used here). Since the force of the wheel along the direction of motion is effectively reduced by a factor of 1/sqrt(2), the velocity must increase by a factor of sqrt(2) to maintain that power output. |
