Go to Post Actually, I think the standard Klingon warning label ought to be sufficient: 'yIQIpQo' (don't be stupid) - Alan Anderson [more]
Unread 15-01-2015, 23:27
z_beeblebrox's Avatar
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Re: pic: Bit Buckets 2015 Prototype Drive Pod
Version 2, ready to be cut tomorrow. Two stages of reduction, for an adjusted robot speed of ~10 fps. Adding a reduction stage only made it ~.25" longer and wider.
Our mostly complete chassis. This will also (hopefully) be cut out tomorrow.
Unread 16-01-2015, 01:36
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
What settings does your team use for the cut? I just realized we have a 60W 30x15 laser cutter sitting in the other room at school.
(2015-?): 973
(2012-2015): 955
Unread 16-01-2015, 08:44
Custom User Title
AKA: Cal
I'm not sure; the settings for our laser aren't "real" units like Watts or Inches/ second. I'd suggest you just try different settings until you find something that works. But do try it; the laser is an amazing resource to have available.
Unread 16-01-2015, 08:55
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Most laser cutters are different. If you want know the setting you can figure them out. But a good starting point is the internet and research into the laser cutter you have.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 16-01-2015, 11:38
Pumped
AKA: Ryan
Definitely, I wasn't trying to just copy paste settings. That rarely works in my experience. I was curious about the speeds you're able to go. Although if the laser doesn't use real units that's disapointing .
(2015-?): 973
(2012-2015): 955
