Go to Post Building a drone during Ri3D is going to be a challenge... - Ginger Power [more]
Unread 15-01-2015, 23:44
BHS_STopping's Avatar
BHS_STopping BHS_STopping is offline
The Freshman
FRC #0842 (Falcon Robotics)
BHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant future
Re: pic: Bit Buckets 2015 Prototype Drive Pod
I hadn't put much thought into it, but I believe you are correct. Those modules will probably need another reduction stage.
I'm just taking the conservation of energy route.
Assume constant power output P. P = force * velocity (dot product used here). Since the force of the wheel along the direction of motion is effectively reduced by a factor of 1/sqrt(2), the velocity must increase by a factor of sqrt(2) to maintain that power output.
[/The Freshman]
