Re: pic: S'no problem
Clever use of your resources. Machining delrin to a nice finish is tricky, but it can be done. Is that why you are sanding, to get a better finish?
If so, then guiding the inevitably long/ stringy chip away from the cutter to prevent it from wrapping works well. No need to move to sanding. Remember to remove the water from the lathe! |
