Go to Post I just want to say that the rack 'n roll was my first year with FIRST! It was the best thing I ever did. I cant wait to learn more when we get to start up again! - ctorloey [more]
Unread 20-01-2015, 16:19
Re: pic: 4242 Preliminary CAD 1
Originally Posted by K-Dawg157 View Post
You have a valid point, programmer.
It would all depend on the material being used, and the orientation it was being used in. Also, how high the support from the back is up the side rails would be important.
I did some calculations with an engineer, and we figured it out that the maximum load the robot (assuming 6 tote or 5 tote bucket and noodle capabilities) would be holding, cantilevered at 6' in the air, would be ~400 foot pounds...
Make sure your material is all good and the supports will hold it and you should be set.
400ft lbs?
For totes cantalievered like 14" out from the front of the robot, I only get arounf 70ft-lbs for a 60lb load. I though you were only supposed to consider the X-distance, not the Y height for torque caused by gravity.
Could you please share your calculations?
