Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Unread 21-01-2015, 07:46
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
Re: pic: 4242 Preliminary CAD 2
Have you put into consideration of the CoG? That's what our team is having issues with right now.
Within the CAD Program's features, we tested the CoG of our original design and found 2 totes would make it tip over and have a catastrophic failure. Since then we have revised the design.
Yeah, we quickly found out that that design does create some interesting CoG problems as well. I urge you to investigate it now while you still have time to fix it.
Did you have CoG problems after weighing down the back end or before? The plan is to put around 25lbs back there.
