Re: pic: Team 1188's Current Design
I'm curious as to what the pistons in the back do
My guess is that horizontal one ejects the stack. The vertical one I'm not so sure about.
How are you handling side loads? The slightest mislignment of the elevator siderails can cause racking if you don't have bearings of some sort there.
EDIT:How are you braking your elevator? Is that piston in the back for ejecting a stack? Are you certain that your carriage bearings and 2x1 can take the loads of the tote stack you will be handling? |
I remembered seeing this yesterday in the Q&A:
Game - The Robot » General Robot Design Q207 Q. In R2, can the team number be vertical on the robot on at least one side? - FRC4470 on 2015-01-17 A. No, a vertical team number could be ambiguous, and doesn't meet the requirements of R2. - Published by GDC |
