Go to Post Mind you... if your ball kicker has as much energy stored up as a trackball launcher, you ought to be able to kick balls up into the stands. - dtengineering [more]
Unread 21-01-2015, 22:34
Re: pic: Team 1188's Current Design
How are you handling side loads? The slightest mislignment of the elevator siderails can cause racking if you don't have bearings of some sort there.
EDIT:How are you braking your elevator?
Is that piston in the back for ejecting a stack?
Are you certain that your carriage bearings and 2x1 can take the loads of the tote stack you will be handling?
Unread 22-01-2015, 07:48
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
I remembered seeing this yesterday in the Q&A:
Game - The Robot » General Robot Design
Q207 Q. In R2, can the team number be vertical on the robot on at least one side? - FRC4470 on 2015-01-17
A. No, a vertical team number could be ambiguous, and doesn't meet the requirements of R2. - Published by GDC
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
