Go to Post “I hope you all had a good weekend. If you didn’t you can try again in five days.” -Honors Debate teacher - Joe J. [more]
Unread 21-01-2015, 23:16
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
Re: pic: 4242 Preliminary CAD 1
Originally Posted by apm4242 View Post
Ronnie - Thanks for the input! We have limited experience with chain driven devices. Given the rollers and the carriage track, I'm not sure where we could put a tensioner. However, we might be able to use something like McMaster's Extended-Life Adjustable
Roller Chain Tensioners
on our carriage to tenison it. One or both of the lift axles are going to be on adjustable flange bearings on the tslot. Do you think this will be sufficient to tension the chains?
RE the ramp - Right now, this ramp would only be able to make 1-stacks oriented in a consistent way for others to pick up (basically removing the inconsistencies of the chute). Although, one of our original designs was an articulating conveyor that would make quick 2 and 3-stacks from the tote chute but we nixed it because we didn't have a strong way to drive the cantilevered conveyor and grip was an issue.
That should do the trick. If not, you can always post again and we can give further instructions.
-Ronnie
