Go to Post Swerve is hard to get right. - marshall [more]
Unread 26-01-2015, 16:14
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
pic: Clippard Air Tank Mount
Unread 26-01-2015, 16:16
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
TylerS will become famous soon enough
Re: pic: Clippard Air Tank Mount
These were printed on our Makerbot Replicator 2 with pla, if anyone was curious.
Purdue University 2019 - Aerospace Engineering
2016 - Team 1747 - Design & Build Mentor
2015 - Team 303 - Coach/Build Captain
2014 - Team 303 - Build Captain
2013 - Team 303 - Driver
2012 - Team 303 - Programming Leader
Unread 27-01-2015, 02:27
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
On what settings did you print? Also, do you know where you sourced your plastic from? I doubt the plastic supplier matters much, but there's a chance that there will be some differences between prints from different suppliers' plastics.
Unread 27-01-2015, 09:26
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
We printed some Clippard tank mounts last year with our Replicator 2, and they do work rather well, but keep in mind they are very brittle compared to the provided mount material...I'd recommend having spares, and possibly even a plan B.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 27-01-2015, 09:35
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
^THIS^
Even though this year there is no defense; without bumpers running into your alliance partner can cause some fairly hard shock to that mount.
The last thing I would want to see is a charged high-side plastic air tank bouncing around in a robot.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 27-01-2015, 14:14
Build Captain
We are using PLA from makerbot, i do not know the settings of the top of my head. I do believe it is a 10% infill.
Thanks for the warning. We will be bringing numerous extras. To test them we mounted it to a piece of plywood, then we proceeded to drop it and hit it with a hammer. It held up!
Unread 29-01-2015, 23:36
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
I don't know if I would use PLA or ABS to make a mount like this. As stated above it can be quite brittle. You can find different versions of PLA and ABS with additives to make it less brittle, but If your printer can handle 300 celcius than buy a roll of PolyCarbonate. It would make a much better mount.
Unread 30-01-2015, 00:32
TylerS's Avatar
AKA: Tyler Stark
Yes PLA and ABS are both brittle when compared to other substances. As Owen said though these were dare I say abusively tested to make sure they'd hold up. Additionally they are kept inside our robot perimeter... We will report back after the season with how they held up.
Unread 30-01-2015, 00:56
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Mmmm... Always thought zipties were the proper way to mount air tanks... Well these look pretty, we're going to need some air tank mounts, gonna pass this along to the CAD guys, probably print at a higher infill.
Thanks!
