Go to Post If you're the smartest person in the room, you're in the wrong room - Ian Curtis [more]
Unread 01-26-2015, 09:23 PM
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
pic: 1736 Robot Casserole's U~Slide Drive
Unread 01-26-2015, 09:25 PM
Ky0t3's Avatar
Ky0t3 Ky0t3 is offline
AKA: Wiley Jordan
FRC #5178 (Nerdy Birds)
Team Role: Electrical
Ky0t3 is an unknown quantity at this point
Re: pic: 1736 Robot Casserole's U~Slide Drive
What are the green inserts on the rpborio and where did you get them?
Unread 01-26-2015, 09:38 PM
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
It looks like something similar to Wildstang's Cable magic. My guess, whatever it is, custom designed or found on the internet, it looks to be a 3D printed part.
http://wildstang.org/blog/?p=472
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 01-26-2015, 11:01 PM
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Yep, Wildstang's Cable Magic. Thanks 111
Unread 01-26-2015, 11:56 PM
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Great to see it in use!
Please check our blog tomorrow. I will be posting up the CAD files for the small/short version for the analog and relay ports.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 01-27-2015, 12:10 AM
AKA: Roger Moore
It looked very similar I just couldn't tell if it was the same or not.
Stronghold
Student 2013-2016
Unread 10-22-2015, 03:35 PM
Deets21's Avatar
Deets21 Deets21 is offline
Team Captain
AKA: Christian Deets
FRC #5442 (Mechanical Monarchy)
Deets21 is an unknown quantity at this point
What were some of the pros and cons of the chassis, not referring to recycle rush, but as a sort of H drive chassis how did it do? I'm exploring different designs for an H drive chassis and noticed yours and though it would be a quick and easy solution to an H drive
Unread 10-22-2015, 04:37 PM
RoundTabler's Avatar
RoundTabler RoundTabler is offline
AKA: Nick Garcia
FRC #1519 (Mechanical MAYHEM)
RoundTabler will become famous soon enough
Do you have CAD or pictures of how you accomplished your spring suspension? I was designing an H-drive this summer, and I couldn't find any pictures of such a suspension.
Unread 10-22-2015, 09:38 PM
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Looks like you're asymmetrically powering only the upper left (in the picture) and the lower right wheel. How's that working out? I've never used omniwheels before - do you have to power all the wheels (like a WCD) or not?
Unread 10-22-2015, 09:46 PM
There are two other belt runs obscured by the flanges on the chassis, all four wheels are powered.
You don't *have* to power every wheel on a drivetrain, but you're wasting tractive force by not doing so. It's a very good idea to do so, particularly when the field isn't flat.
Unread 10-22-2015, 09:47 PM
EricH EricH is offline
Nope, they're powering all of them. The frame hides the near-side belt on both sides.
Omnis being all/not all powered depends on the exact type of drive. If they're in tank configuration, they don't all need power. But if you're doing something funny--say, omni-directional movement--you'll need 'em all powered (in general). And, in general, you want all your wheels that are on the ground powered (unless you specifically don't).
Unread 10-22-2015, 10:56 PM
AKA: Thomas
I see it now. Thanks!
+1. I'm thinking about doing something with omniwheels right now in the preseason, and it'll be great to see some examples of spring suspension.
Unread 10-23-2015, 07:45 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by gurellia53 View Post
This wheel is on a coil spring suspension to improve strafing
What is the vertical travel at the wheel axle? Would it let you go onto the scoring platform at an angle without banging things up too badly?
We're doing a similar project, but we're mounting our strafe wheel pneumatically, so we can lift it when we don't need to strafe or when we need to go over an obstruction. Pics to follow.
Unread 10-24-2015, 12:28 AM
jeremylee's Avatar
jeremylee jeremylee is offline
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Travel was only around an 1/8 or so after we dialed in our downforce. Since the wheel was offset towards one end, we still had control of the robot even if the straffe wheel was holding the other two off the ground. I don't think our drivetrain held us back really even when we were forced to go back to open loop due to gyro issues.
I like the pneumatic approach better than adjustable spring. We'd lose a lot of pushing power if we used the spring approach in a year with defense as it took more downforce on the straffe wheel than was originally expected for good straffing performance.
I also like how the Robowranglers did their double center wheel in 2014. I we do h-drive again, I'd strongly consider this approach.
Unread 10-24-2015, 12:44 AM
jeremylee's Avatar
Pros:
1. Easy way to add h-drive to kit.
2. U approach straffed well even with a heavy load of totes on the straffe wheel side on robot.
3. Clearance to cross bump easily
4. Ajustable spring for allowed us to dial in quickly during a regional.
Cons:
1. Reduced pushing capability due to spring approach to load center wheel in games of defense.
2. Limited travel of center wheel due to using kit plates for 5th wheel
3. Heavy
4. Needed gyro to help compensate for tendacy to turn during straffing.
