Go to Post Goodness gracious professionalism - Billfred [more]
Unread 30-01-2015, 13:14
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
pic: 80/20 Flanged Button Head Fasteners
Unread 30-01-2015, 13:15
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: 80/20 Flanged Button Head Fasteners
Yup, flanged screws are great for retention on the ends of shaft. Also dropping a washer into the depths of your robot is never fun. We buy ours at Mcmaster.
http://www.mcmaster.com/#91355a080/=vozj62
Greg Needel│www.robogreg.com
Unread 30-01-2015, 14:08
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Totally missed these! What a headache saver....thanks, Greg.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 30-01-2015, 15:02
nathannfm's Avatar
AKA: Nathan
FRC #3940
Note that you can strip the hex out of a button head much easier than out of a socket head, especially when the screw is retained with Loctite as should be done on a spinning shaft like this. We had this problem numerous time on our drive last year and have since switched to socket heads with washers. If only socket heads with flanged didn't cost $4 PER SCREW.
Unread 30-01-2015, 15:07
Assuming you're using a reasonable size like #10-32 or larger, you're putting some mean torque into the bolts, using junk wrenches, or using junk bolts. We haven't had issues with buttonheads stripping out.
#8-32 and smaller on the other hand, much easier to strip.
Unread 30-01-2015, 15:53
I've never stripped out a hex socket screw, button or socket. Maybe getting some new allen keys could help.
Unread 31-01-2015, 07:47
AKA: Dana P. Henry
Don't use the ball end of the allen wrench. If the straight end is getting too worn, grind it shorter.
Unread 31-01-2015, 12:24
nathannfm's Avatar
AKA: Nathan
FRC #3940
Standard 10-32 black oxide from McMaster...I can't comment in the meanniss of the pit crew last year , but I will take a close look at our wench tips, I know some of them are at least 10 years old...
