Go to Post Doesn't make sense, Karthik. ...... You don't scare me, other than the way 1114 normally does. - EricH [more]
Unread 03-02-2015, 19:19
PandaHatMan's Avatar
PandaHatMan PandaHatMan is offline
AKA: Wallpe
PandaHatMan is an unknown quantity at this point
Re: pic: 1747 Drivetrain teaser
Originally Posted by wilsonmw04 View Post
I have done that in the past to help drill through thin stock. It keeps you from collapsing the walls.
This is true. It prevents us from over-tightening bolts . We also decided to do our entire frame from 1/16th box stuffed with wood because it weighs slightly less than 1/8th. It means we run through less stock and less money than mixing the two and we can stuff only the pieces we want. Even better, stress analysis through Inventor shows it to be much stronger than just 1/8th box channel .
Originally our plan was to use T-nuts as much as possible, but we found it unnecessary after getting into build season a bit more.
