Originally Posted by PandaHatMan
This is true. It prevents us from over-tightening bolts  . We also decided to do our entire frame from 1/16th box stuffed with wood because it weighs slightly less than 1/8th. It means we run through less stock and less money than mixing the two and we can stuff only the pieces we want. Even better, stress analysis through Inventor shows it to be much stronger than just 1/8th box channel  .
Originally our plan was to use T-nuts as much as possible, but we found it unnecessary after getting into build season a bit more.
What type of wood? Does the stuffing run the entire length of a rail?
