Go to Post You know you are a true tech geek when you end up on top of the Sears tower, and the only pictures you post are the ones of the radio antennae. ;) - Tom Line [more]
Unread 02-02-2015, 15:53
holygrail's Avatar
holygrail holygrail is offline
Gavin Wood
FRC #1939 (The Kuhnigits)
holygrail is just really niceholygrail is just really niceholygrail is just really niceholygrail is just really nice
Re: 2363 feeder station robot loading
Cool!
Just a thought. Could you shave off a few seconds by just leaving the first tote on the ground and sliding the second one on top of it, then pick both up at once?
Good luck this year! Looks like a strong design.
Unread 03-02-2015, 08:21
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Originally Posted by holygrail View Post
Cool!
I think a lot of that depends on what the throughput of a HP can be. Shaving the time off of the robot doesn't help if the robot is waiting on the human player. I think that will be the limiting factor for a lot of robots that feed from the human player station.
Unread 03-02-2015, 09:22
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Love the design! I'm always curious to see what Triple Helix will be building and how you'll do it... imo, you guys always do a great job picking a good strategy from game analysis.
I disagree; I think *most* HP-loaded teams will be robot-limited rather than HP-limited. That said, the *good* HP-loaded teams will be HP-limited... and that with a well-practiced HP! I certainly think you guys will fall into the category of 'good' HP-loaded teams though! :-)
Seems to me although your HP is being smooth, he could still be 30-60% faster... perhaps by situating totes such that he doesn't need to walk around that would itself be a fair bit quicker. Then of course there's just being practiced and even quicker (think 2013 HPs)! Seems like he also is usually needing to wait to release the tote through the Chute Door, so that's a pause (although not currently his fault).
Seems like the two big slow-downs on your robot are retrieving the tote after it slides through (looks like 2-3s to me) and the requirement to raise and lower your stack repeatedly. There's certainly potential to speed up the first one quite a bit without dramatic re-design, but the second one's harder to speed up dramatically without changing the fundamental process.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 03-02-2015, 09:50
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Great work...
Your totes never seem to have the dreaded, stand up on end problem we have seen in other videos.
Wondering how the dimensions work out, and if adding a wheel in the middle of your arm would help if you ran it in reverse while dropping the crate to pull that leading edge out to prohibit the stop on end.
With the totes above, it looks like you could not stand it on end, but one that stalled with just leading point resting maybe a problem.
The sooner we get behind schedule, the more time we have to catch up.
Unread 03-02-2015, 11:06
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Great work. This looks really familiar.
#teamdiscbrake
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 04-02-2015, 10:36
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
What is the passive system that you are using on your elevator arm?
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 04-02-2015, 10:40
Flywheel Police
I'm assuming you are referring to the system that is gripping the totes. They are just lexan fingers that are angled in.
Unread 04-02-2015, 10:46
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Based on their previous thread, they appear to be bent polycarbonate/lexan tabs, similar to Ri3D Indiana.
Unread 04-02-2015, 13:27
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
Our early prototyping focused on comparing the two stacking methods of always stacking from the floor vs stacking on a "seed" tote. Based on our testing, we decided to focus on stacking from the floor.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 04-02-2015, 13:35
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Could you explain your process for comparing these two stacking methods? I'm curious.
Excellent test videos, thanks for sharing!!
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 04-02-2015, 13:41
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Originally Posted by tr6scott View Post
Great work...
The tote starts with zero linear velocity and zero angular velocity. For the tote to tumble, the CG of tote must pass the end of the ramp. When the CG of the tote passes the end, there is a couple between the weight of the tote acting at the CG and the reaction from the end of the ramp. This couple imparts angular velocity to the tote.
Visualize the angled ramp from the feeder station as extending to an arbitrary height from the floor. Going to one extreme, imagine the dropoff from the end of the ramp being 1 inch. The sliding tote would contact the floor before the CG passed the end of the ramp, so no tumble. (neglecting the horizontal force of the point in contact with the floor) As the height of the dropoff increases, the more likely the tote is to tumble. The trick is to extend the ramp until the dropoff height is low enough that the tote doesn't tumble and end up on end.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 04-02-2015, 14:04
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
For the seed tote method:
1) Place a seed tote where we think the stack will be.
2) Feed many, many, totes onto the seed tote from the feeder station, doing everything we can to make it mess up.
3) Add structure to prevent mis-stacking.
4) If structure looks practical, and mis-stacking is reduced to an acceptable level, or if structure is too complicated, stop and draw conclusions. Else, return to step 2.
For the floor loading method:
1) Load many, many, totes onto the floor from the feeder station, doing everything we can to make it mess up.
2) Add structure to make totes end up in the proper spot for stacking.
3) If structure looks practical, and mishaps are reduced to an acceptable level, or if structure is too complicated, stop and draw conclusions. Else, return to step 1.
Final step: Compare the structure/mechanisms required to make the two methods work, and choose to implement the method which works best with how we want to play the game and how the rest of the robot is shaping up.
This pretty much summarizes how we do all our prototyping. We try to fail quickly, tweak, and repeat. The trick when prototyping is to know when something is failing because it's a bad idea vs poor execution of a prototype. The students are often far to quick to discard a good idea because the first try doesn't work. Often, just the right tweak turns a complete failure into a complete success.
We live for those eureka moments. Whether we win or lose competitions, it's those moments when a student's idea makes something just "click" that will stick with them and influence them to become engineers.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 04-02-2015, 14:19
waialua359's Avatar
waialua359 waialua359 is offline
AKA: Glenn
FRC #0359 (Hawaiian Kids)
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
That's a smooth looking feeder station robot.
Great job on the disc brake! We have one working at the moment as well.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 04-02-2015, 14:20
waialua359's Avatar
AKA: Glenn
#teamdiscbrake
-Nick
Haha!
Unread 04-02-2015, 15:33
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Now we just need to speed things up a little...
6 tote stacking at the feeder station
Very smooth. Ruined steak!! (Well done!!)
It looks like if you needed to you could stack 2 at a time from the floor--is that true or does only one fit under an elevated tote?
