Go to Post "which came first, the hamster or the toad?" - dlavery [more]
Unread 09-02-2015, 14:58
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Team 4719 Control Board
Originally Posted by snoman View Post
do you still need the DC/DC power regulator when you are using the VRM?
If you need more than 500ma at 5v, perhaps for an Axis ethernet camera, you will need something in addition to the main VRM. The old CPR-360 is a good choice, except that its output will start to droop when the battery voltage falls below about 7.5 volts.
