Go to Post This was my freshman year, and I can't wait for next year! - Éowyn [more]
Unread 09-02-2015, 12:51
obselete1 obselete1 is offline
FRC #0269
obselete1 is an unknown quantity at this point
pic: Conveyer belt tracking
Unread 09-02-2015, 12:53
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: Conveyer belt tracking
Two years ago we used rubber belts and just placed a sticky piece of rubber about a cm wide in the center of where we wanted the belts to ride. They would want to center on this piece of rubber.
In this picture you can see the place rubber on the rollers where we have belts prior to removing them.
Unread 09-02-2015, 13:13
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
If this is flat belt, build up the area under where you want the belt to stay with tape.
Flat belts will track to stay on top of a RAISED area of your roller.
It sounds very counter-intuitive, but try it and it will keep your belts in place.
Unread 09-02-2015, 13:28
FRC #0269
Thanks for the ideas folks!!
Unread 09-02-2015, 13:29
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
We have done this in the past with great success. Electrical tape works well for this purpose.
Unread 09-02-2015, 13:31
Fields's Avatar
Fields Fields is offline
Classic
FRC #5637 (Titanium Polars)
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
I concur, look up information on "crown roller" for the "why" in how it works. For your axles you'll have multiple crowns.
Unread 09-02-2015, 16:03
Any chance the 'crown' method works for timing belts? We're adjusting our approach to one of our designs, and pulley alignment may not be perfect afterwards.
Unread 09-02-2015, 16:09
RoboChair's Avatar
AKA: Devin Castellucci
Crowned Pulleys, make them your friend. My first robot I made I discovered this phenomena by accident, it was a very happy accident.
Unread 09-02-2015, 16:16
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Flanged pulleys, for us, have always been adequate in cases of slight mis-alignment.
Unread 09-02-2015, 16:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The physics works for flat belts on a smooth shaft. Teeth are going to complicate things a little.
Unread 09-02-2015, 16:28
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Timing belts usually run in sheaves (V-belt grooves) rather than on crowns. The flanges around the sheaves maintain alignment. Note that sometimes only one pulley will have these flanges, and the others are wide enough to work where the guided one leads. The drive belts on this year's KOP drive are a good example.
Here's a better example showing one flanged pulley and one unflanged pulley.
Unread 10-02-2015, 14:23
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
https://www.youtube.com/watch?v=6sM0Qjumyro
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
