Go to Post It's very confusing to other people on the message boards when you make things up that are incorrect and assert them as fact. Please don't do this. - Dave Flowerday [more]
Unread 12-02-2015, 10:01
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron)
pic: 4901 won't run out of air this season. That's for sure.
Unread 12-02-2015, 10:03
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
Re: pic: 4901 won't run out of air this season. That's for sure.
What's the weight?
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
Unread 12-02-2015, 10:06
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Originally Posted by JohnFogarty View Post
How long does it take to charge that thing?
... and for that matter, how long does it take to dump after the match?
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 12-02-2015, 10:08
nuclearnerd's Avatar
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud of
Harbor Freight has the tank listed at 15 pounds. About the same weight and capacity of 30 clippard tanks.
I'm smiling looking at this photo. We had similar air use issues with our pneumatic elevator in Week 4 because of the way we (mis)read the compressor specs. Our choice was either mount 30 tanks, or retrofit a motorized winch. We went with the winch, but the switch ate up most of Week 5 (and a good chunk of our budget). I hope the "more tanks" choice works well for you!
Unread 12-02-2015, 10:33
MrForbes MrForbes is online now
it takes our little Viair compressor just over half a minute to fill our one long skinny (2012 KOP) metal storage tank. I'm guessing it will take that compressor at least 5 minutes to fill the big tank. Hopefully you can get it done before each match....
Unread 12-02-2015, 10:55
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
We are using that same compressor, and a metal Viair tank. However, we are thinking that half a gallon of air should be enough.
Five gallons is a lot of air. Based on measurements my team reported earlier, I would estimate this compressor would require about four minutes to recharge a five gallon tank from ~100 PSI back to ~120 PSI. So with a tank that large, it is unlikely you would see a benefit from have the compressor on board.
Richard Wallace
since 2003
Unread 12-02-2015, 11:00
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
...without burning up that compressor that I'm guessing wasn't designed for continuous duty.
Unread 12-02-2015, 11:04
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Last year, I saw a team from Mexico do something similar. It took them about 5 minutes to recharge. If they made it to the finals, I have no idea what they would do to reset for the back to back matches.
Unread 12-02-2015, 11:12
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Actually, the VAIR 250c is rated for a 100% duty cycle.
--Jacob
Illinois FTC FTA
Unread 12-02-2015, 11:14
tickspe15's Avatar
Purdue University
AKA: Spencer Tickman
The compressor they are using, the viair 250C, is rated for continuous duty.
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 12-02-2015, 11:28
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Why would they dump their stored air after the match?
Andrew Basse
Unread 12-02-2015, 12:38
Without seeing the rest of the robot design, we can only guess.
Unread 12-02-2015, 14:13
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I believe that this was explicitly required in previous years - that all stored air must be dumped at the end of the match. I couldn't find anything stating or implying so in the 2015 game manual.
Unread 12-02-2015, 14:37
SM987 SM987 is offline
AKA: Stephen McKinney
FRC #0987 (The High Rollers)
SM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond repute
If you find yourself close on weight, go for the 7gal aluminum one at HF. Saves a little bit and then you'll really have to try to run out of air.
Attending:
2016 Los Angeles Regional
2016 Las Vegas Regional
2016 Arizona West Regional
2016 FIRST Championship
Team 987 - The Highrollers - Las Vegas, Nevada
Unread 12-02-2015, 17:36
We did a lot of math on the volume of air our Cylinders use per stroke and we found that an air tank with volume like this is almost a necessity.
The tank is 15 LBS. (I am aware of the light weight version at harbor freight and we'll keep that in mind if weight is problem, which at the moment our robot is about 30 pounds under weight without the tank on.
Our plan was to use the compressor off-board. If we needed extra weight...on it would go. The compressor is also roughly 15 pounds.
100% Duty cycle at 100 PSI. Charge time is 5 minutes from empty to full. We don't need to empty the system after every match. We would only do so in the times where we needed to. I also checked the rules for that.
John Fogarty
