Go to Post ...these guys have taken it to a new level. (I want to be part of a team like that.) - Tetraman [more]
Unread 12-02-2015, 10:36
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: Compressor Fan Mount
Originally Posted by brrian27 View Post
Last year we had a fan for the compressor (mounted to the electrical board, not altering the compressor), and were told to take it off by our inspector at Orlando. Not sure if that is really against the rules, or if most inspectors would care.... But regardless, nice design!
You were told to take it off? Did they cite the rule that it was breaking? We had a fan pointing at our compressor and made it through 2 Regional inspections and the Championship inspection with no problems.
Unread 12-02-2015, 10:42
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Being asked to remove it could come from two sources: first, the inspector may not realise it was a legal fan for the robot, and it would be an ideal time to respectfully ask for a second opinion from the LRI and make your case for it being legal. Second, without actually seeing the fan that was used, it's possible that the fan was NOT one of the ones that has been distributed in the KoP over the years - those, and any that are integral to a COTS computing device or constructed from a legal motor are the only ones that are legal for use on a robot.
2016: Lake Superior WFFA
Unread 12-02-2015, 10:44
evanp1816 evanp1816 is offline
AKA: Evan P.
FRC #1816 (The Green Machine)
evanp1816 is an unknown quantity at this point
My LRI said the same thing too. What a coincidence!
Unread 12-02-2015, 10:53
Flywheel Police
That could very well be the case, which is why I was curious of the reasoning.
Unread 12-02-2015, 10:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
It's a nice design, but you are definitely reducing the amount of thread engagement those bolts have.
Unread 12-02-2015, 12:38
Jordans16117 Jordans16117 is offline
FRC #1816
Jordans16117 is on a distinguished road
Ya It was suppose to be a joke.
Unread 12-02-2015, 10:58
MrForbes MrForbes is offline
Having a fan pointed at your compressor, and having a fan mounted on your compressor, are not the same thing. We have a fan pointed at our compressor also, it's mounted on a bracket which is attached to the robot belly pan.
Unread 12-02-2015, 11:14
Flywheel Police
Last year we had a fan for the compressor (mounted to the electrical board, not altering the compressor)...
That's what I was referring to.
Unread 12-02-2015, 11:21
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I'll throw my opinion in here (and as I am the LRI at your week 1 event, you may want to know what it is..... )
Removing the bolts on the compressor, installing your bracket (which is very nice, by the way) and then re-installing the bolts, is a no-no.
There is a simple test for if something relating to "modifying" a pneumatics component is allowed: Did you pick up a tool? If so, it's probably not allowed unless it's on the specific list in R-65. R-65c allows you to assemble components together, such as installing a COTS threaded coupling into a threaded orifice in the COTS cylinder. If you are claiming you are assembling pneumatic components under R-65c, then R66 lists the allowed components, and your fan bracket is not listed. So R-65c does not apply.
I highly recommend mounting a legal fan next to the compressor, my team does that most years. Not sure why an inspector would have required a team to remove a fan. That's one of those situations where you should always respectfully and graciously request a second opinion from the LRI at the event.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 12-02-2015, 13:31
AKSoapy29's Avatar
AKSoapy29 AKSoapy29 is offline
Driver, Prog, Elec, Pneu, Etc.
AKA: Andrew K.
FRC #2169 (KING TeC)
AKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura about
Somehow we got away with this last year, except it was a different design. I didn't realize it was breaking the rules, shoot... And I was proud of it! I think I'm going to try and re-use it, except not mount it under the bolts, but instead on top of them. I'll try some stuff.
Andrew K.
KING TeC 2169
League of Veterans - FTC3385
Head of Web, Primary Driver, Programming, Electrical, Pneumatic
Unread 12-02-2015, 19:09
brrian27's Avatar
brrian27 brrian27 is offline
the Mormon
AKA: Brian
FRC #2383 (Ninjineers)
brrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond repute
I don't remember exactly, I wasn't in the pit during the inspection. I believe the inspector said it was an "unfair advantage," which doesn't make sense because anyone could do it.... But our compressor wasn't too stressed last year, so it wasn't something that really mattered.
team2383.com
2011-14: Student- Team 2383, the Ninjineers (2013-14: Drive Team Coach & 2014: Co-Captain)
5 Team Spirit Awards --- 1 Excellence in Engineering Award --- 1 Regional Finalists
Currently : Student- Brigham Young University
2015 SOUTH FLORIDA REGIONAL CHAMPS #BLUEBANNERYEAR ARCHIMEDES DIVISION FINALISTS
