Go to Post If it's anything that FIRST's competitive spirit has taught me, its to take the good with the bad. - Mike Schroeder [more]
Unread 12-02-2015, 10:58
MrForbes MrForbes is offline
Re: pic: Compressor Fan Mount
Originally Posted by notmattlythgoe View Post
You were told to take it off? Did they cite the rule that it was breaking? We had a fan pointing at our compressor and made it through 2 Regional inspections and the Championship inspection with no problems.
Having a fan pointed at your compressor, and having a fan mounted on your compressor, are not the same thing. We have a fan pointed at our compressor also, it's mounted on a bracket which is attached to the robot belly pan.
Unread 12-02-2015, 11:14
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Last year we had a fan for the compressor (mounted to the electrical board, not altering the compressor)...
That's what I was referring to.
Unread 12-02-2015, 11:21
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I'll throw my opinion in here (and as I am the LRI at your week 1 event, you may want to know what it is..... )
Removing the bolts on the compressor, installing your bracket (which is very nice, by the way) and then re-installing the bolts, is a no-no.
There is a simple test for if something relating to "modifying" a pneumatics component is allowed: Did you pick up a tool? If so, it's probably not allowed unless it's on the specific list in R-65. R-65c allows you to assemble components together, such as installing a COTS threaded coupling into a threaded orifice in the COTS cylinder. If you are claiming you are assembling pneumatic components under R-65c, then R66 lists the allowed components, and your fan bracket is not listed. So R-65c does not apply.
I highly recommend mounting a legal fan next to the compressor, my team does that most years. Not sure why an inspector would have required a team to remove a fan. That's one of those situations where you should always respectfully and graciously request a second opinion from the LRI at the event.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 12-02-2015, 13:31
AKSoapy29's Avatar
AKSoapy29 AKSoapy29 is offline
Driver, Prog, Elec, Pneu, Etc.
AKA: Andrew K.
FRC #2169 (KING TeC)
AKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura about
Somehow we got away with this last year, except it was a different design. I didn't realize it was breaking the rules, shoot... And I was proud of it! I think I'm going to try and re-use it, except not mount it under the bolts, but instead on top of them. I'll try some stuff.
Andrew K.
KING TeC 2169
League of Veterans - FTC3385
Head of Web, Primary Driver, Programming, Electrical, Pneumatic
