Go to Post If you're doing it to win, you're doing it wrong. Teams who truly understand why they are doing what they do will win Chairman's simply as a result, an added benefit. The award isn't the goal. It's the impact you create, and the results you see. - dcarr [more]
Unread 12-02-2015, 11:19
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: pic: Compressor Cooler
I wouldn't think zip ties would be a modification. I might worry, however, about what happens to that zip tie if the compressor gets hot...
2016: Lake Superior WFFA
Unread 12-02-2015, 11:30
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
These would work nicely I would think.
Unread 12-02-2015, 12:11
hunterteam3476's Avatar
hunterteam3476 hunterteam3476 is offline
AKA: Hunter
FRC #3476 (Code Orange)
hunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud of
That look really good! keep up the good work.
http://www.TeamCodeOrange.com
2015 - Championship - Tesla Champions, #2 pick
2015 - San Diego - Regional Chairman's Award, #1 Pick, Finalists
2015 - Inland Empire - Engineering Inspiration Award, #2 Pick, Finalists
2014 - Championship, Excellence In Engineering Award
2014 - Las Vegas- #3 pick, Finalists
2014 - San Diego - Regional Chairman's Award, Regional Imagery, #2 Alliance Captain, Semi Finalists
2013 - Championship - Newton Champions, #3 pick
2013 - Inland Empire - Innovation in Control Award, #2 Alliance Captain, Finalists
2013 - San Diego - Industrial Design Award, #4 Pick, Semi-Finalists
2012 - San Diego -Regional Winner, Excellence In Engineering Award
2011 - San Diego - Judges Award
Unread 12-02-2015, 13:14
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
I know the compressors get hot but is it really necessary? If it works effectively then it's totally worth it.
Alumni from 75 and 1885
Unread 12-02-2015, 13:47
MrForbes MrForbes is offline
It depends on how often the compressor runs. The little compressor is rated at only 9% duty cycle, so if you don't let it cool off for 20 minutes between matches, it can over heat enough to either damage the compressor, or melt the plastic tubing connecting the compressor to the rest of the pneumatic system.
Pointing a fan at the compressor is a good idea. Mounting the fan to the compressor itself to accomplish this, might not be a good idea (and it might be contrary to the rules about modifying pneumatic components)
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Where have these been all my life?
