Go to Post At GLR our team only had to deal with a bunch on kids seeing snow for the first time. With all the ensuing snow fights and vainly trying to run up the giant snowy hill behind the arena. - Kevin Sevcik [more]
Unread 12-02-2015, 11:21
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: pic: Compressor Fan Mount
I'll throw my opinion in here (and as I am the LRI at your week 1 event, you may want to know what it is..... )
Removing the bolts on the compressor, installing your bracket (which is very nice, by the way) and then re-installing the bolts, is a no-no.
There is a simple test for if something relating to "modifying" a pneumatics component is allowed: Did you pick up a tool? If so, it's probably not allowed unless it's on the specific list in R-65. R-65c allows you to assemble components together, such as installing a COTS threaded coupling into a threaded orifice in the COTS cylinder. If you are claiming you are assembling pneumatic components under R-65c, then R66 lists the allowed components, and your fan bracket is not listed. So R-65c does not apply.
I highly recommend mounting a legal fan next to the compressor, my team does that most years. Not sure why an inspector would have required a team to remove a fan. That's one of those situations where you should always respectfully and graciously request a second opinion from the LRI at the event.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 12-02-2015, 13:31
AKSoapy29's Avatar
AKSoapy29 AKSoapy29 is offline
Driver, Prog, Elec, Pneu, Etc.
AKA: Andrew K.
FRC #2169 (KING TeC)
AKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura about
Somehow we got away with this last year, except it was a different design. I didn't realize it was breaking the rules, shoot... And I was proud of it! I think I'm going to try and re-use it, except not mount it under the bolts, but instead on top of them. I'll try some stuff.
Andrew K.
KING TeC 2169
League of Veterans - FTC3385
Head of Web, Primary Driver, Programming, Electrical, Pneumatic
