Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Unread 12-02-2015, 13:14
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
Re: pic: Compressor Cooler
I know the compressors get hot but is it really necessary? If it works effectively then it's totally worth it.
Alumni from 75 and 1885
Unread 12-02-2015, 13:47
MrForbes MrForbes is offline
It depends on how often the compressor runs. The little compressor is rated at only 9% duty cycle, so if you don't let it cool off for 20 minutes between matches, it can over heat enough to either damage the compressor, or melt the plastic tubing connecting the compressor to the rest of the pneumatic system.
Pointing a fan at the compressor is a good idea. Mounting the fan to the compressor itself to accomplish this, might not be a good idea (and it might be contrary to the rules about modifying pneumatic components)
