Go to Post Yes, a good driver can effectively be the element that closes the loop, but only when there is a driver at the controls. - Alan Anderson [more]
Unread 13-02-2015, 00:38
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
Re: pic: 4183 Wooden Swrrrv
I want a video of this driving, please. If that module holds up, that would be really awesome.
EDIT: Is that wooden disc on a bearing, or are you using a wood bearing?
The wood disk is a bearing, laser cut edge on laser cut edge with some grease.
Originally Posted by cgmv123 View Post
I hope the gears aren't wood too.
Just the steering gears.
Originally Posted by bkahl View Post
What are you using to support the robot weight?
There will be a thrust bearing between the top of the module and the top sheet on the housing.
