Go to Post If this photo doesn't tell us why a photographer is important to a team, I don't know what will. - JaneYoung [more]
Unread 14-02-2015, 21:10
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
pic: 865 flipped CIM WCD gearbox
Unread 14-02-2015, 21:11
Joey Milia's Avatar
FRC #0192 (GRT)
Re: pic: 865 flipped CIM WCD gearbox
I like it
What are the tooth counts of the belt and pulleys you're using?
Also, are you doing anything to protect the cims from impact?
Unread 14-02-2015, 21:14
Andrew Lawrence
Definitely loving the compactness. I've always been a bit nervous to use belts in a drive transmission, but it looks like you've pulled it off pretty successfully. Props to you for this great design! Is there any reason you didn't lighten the plates?
Unread 14-02-2015, 23:52
mman1506's Avatar
no team (WARP7)
Originally Posted by Joey Milia View Post
I like it
Thanks,
the pulleys are 24 and 30 tooth and the belt is a 50 tooth.
The omni sticks out past the CIM motor by about a 1/4 of an inch so that should give it some protection from side impacts. We've been considering some sort of "splitter" to prevent something getting in front of the gearbox or a polycarb bumper outside of the transportation area.
2016: FRC 865 Mentor
Unread 15-02-2015, 00:08
Joey Milia's Avatar
FRC #0192 (GRT)
Ah ok cool, in the pic it looks like the cims stick past the wheel so I was worried. I just noticed you said the belts were gt3, were did you sorce them?
Unread 15-02-2015, 00:16
mman1506's Avatar
no team (WARP7)
We were originally going to have the CIM mount plate waterjet cut where ON/OFF cycles are a big factor of machine wear. While we ended up laser cutting them we decided against a lightening pattern due to minimal weight savings and the potential of impact to the gearbox.
Unread 15-02-2015, 00:18
mman1506's Avatar
no team (WARP7)
My mistake, the belts are GT2 from SDP-SI
Unread 17-05-2015, 21:44
mman1506's Avatar
no team (WARP7)
I thought I'd update this post with a long term review for those who are looking to do something similar.
I'm happy to report that we had zero issues with the gearbox after three competitions. There doesn't appear to be any significant belt wear and the CIMs have held up fine after bashing them numerous times.
We also added grayhill encoders for our 3rd competion using the "cheesy poof method" into the input reduction shaft.
