Go to Post me: "Was I on fire!?" Roberto: "Sure you were. We only let you burn for about 10 seconds.":yikes: - El Geffe [more]
Unread 15-02-2015, 16:20
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
pic: 3081 servo operated dog gear
Unread 15-02-2015, 16:25
AKA: Steve Peterson
Re: pic: 3081 servo operated dog gear
Here's the first winch our team has built that includes a dog gear mechanism to prevent back driving. We're using a servo to actuate the dog. It took about 2 hours to build the servo attachment.
Parts:
Toughbox
.090 aluminum sheet to attach servo
servo
.500x.750 aluminum bar
.125x.750 aluminum bar
AndyMark AM-0096A hubs
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 15-02-2015, 18:58
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
TylerS will become famous soon enough
Do you have the servo move the bar out of the way whenever you are moving the to drum?
Purdue University 2019 - Aerospace Engineering
2016 - Team 1747 - Design & Build Mentor
2015 - Team 303 - Coach/Build Captain
2014 - Team 303 - Build Captain
2013 - Team 303 - Driver
2012 - Team 303 - Programming Leader
Unread 15-02-2015, 19:31
Jonathan Cheng's Avatar
Jonathan Cheng Jonathan Cheng is offline
FRC #0334 (Tech Knights)
Jonathan Cheng is on a distinguished road
How well does it disengage under high loads?
Unread 15-02-2015, 22:24
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What does the servo actuate, and what does the dog gear engage with? I see what looks like it might be a ratchet, but I can't tell how it would let the teeth move in either direction.
Unread 15-02-2015, 23:23
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
It is pretty simple, there is a spring that holds the locking mechanism in place, and as the spindle is spun the lock positions itself in the gear. Then when we want to unwind the spindle. The motor spins just slightly to release the tension on the lock, and then the servo moves the lock into a neutral position allowing the spindle to unwind.
Unread 15-02-2015, 23:27
Oblarg Oblarg is offline
AKA: Eli Barnett
Having used (and eaten through) hand-made ratchets before, the one suggestion I have is to keep an eye out for wear and have plenty of spares.
"The breakfast of champions!"
