Thread Tools |
Rating:
Display Modes |
Re: pic: Compressor Backpack
I think we may be able to get away with this at some events IF we only use it to compress when testing systems in the pit and practice field. This could actually be useful for the practice field, due to the limited time.
But we have to remember that we need to compress with our single on board compressor before an official MATCH to make sure the matches themselves are all done by the book. |
This might help you.
If you have a large air tank off the robot and use the robot compressor to fill it the morning of the competition, you could then use air from this tank to pre-fill your onboard tanks before each match. This would still meet the requirement that all air comes from the one compressor and allow you to hit a higher psi before starting your compressor to finish filling the tanks. I do not believe there is a rule stating that air cannot be temporarily stored off the robot. |
Now, if you use Quantum Entanglement to activate a vent on the off board tank, I wonder if that would violate the no other wireless communication rule. Last edited by rich2202 : 16-02-2015 at 07:26. |
R74 and R75 provide (only) two methods of using an off board compressor, illustrated in Fig. 4-8 and Fig. 4-9. Neither of these permissible methods includes off board air storage.
Honestly, this backpack scares me from a safety perspective. What happens to the unlucky person wearing it if a tank should explode? As an LRI, I would insist it be removed from the venue, and I bet the UL Safety advisors would agree. |
If the pack got dropped while it was pressurized really bad things could happen. Please do not use this device, ever. I know it seems cool, but it's just asking for a disaster. |
It's really, really cool in concept. Pretty much anything turned into a backpack is pretty awesome, and you've obviously made something that serves a very good purpose. I agree, though, about the safety problem. Nobody can stop you from using it in your shop, but i'd suggest using metal air tanks for something like this.
I agree with Jon.
At LRI training at HQ in early Jan, one of our fellow CMP LRI who works at an Army Testing Lab hired an intern to test the most common plastic tanks available to FIRST teams. The results for the black Clippard tanks was good. The white Clippard tanks (See the Manual for the exact p/n) were ruled illegal after several failures during the season and the resultant testing this summer at the Army Lab. And if I remember right, the performance deteriorated when damaged, nicked or abused, even slightly. Kudos for thinking outside the box, but you won't see one being used on my team or at my event. Period. End of story. Last edited by Rosiebotboss : 16-02-2015 at 10:03. Reason: Additional detail aded. |
Not all white plastic air tanks are the clippard ones
If I'm not mistaken, the air tanks in the picture are, in fact, from pneuaire, not clippard. Not that that makes it a good idea. |
#10
(deleted)
#11
If the goal is to have a way to charge the tank for practice, it would be much simpler to use a single A/C air compressor than four or more 12V ones.
#12
That looks super dangerous. |
#13
I was just thinking about this last night, and we should at least encase the entire pack in a sheet of some thick polycarbonate, or some other method of keeping everything inside the pack in the event of any catastrophic failure. We should also replace the tanks with their metal equivalents.
I did mention that this pack is unfinished, and still requires some more safety features. We just needed something built to use for practice, and plastic tanks are what we had on hand. If this is ever used, it is easily depressurizable for wearer movement to help reduce any accidents. This is only intended for use in safety glass areas around the robot when the robot is running and only when it is needed. Having a member of our team walking around an event with a pressurized pneumatic backpack is just plain idiotic, and is not our intent with this system. We don't intend to keep it pressurized for any extended length of time; only when we need to repressurize the robot for practice or testing. Perhaps a tankless backpack may be the best option for safety, so pressurized air does not get stored in the pack at all. If we deem this pack too unsafe still, we will make sure to keep it out of an event. Thank you all for your concern. I'm also all about safety, and I want to do my best to help make this pack safer for my team members and every volunteer, student, mentor, and attendee at an event, if that's possible. ![]() Last edited by bEdhEd : 16-02-2015 at 11:20. |
#14
It's a great out of the box idea, so you should feel great about that.
I think you got great rules feedback, with some redesign and some Q&A responses you'll have a working system. Metal tanks, shroud, etc are the first steps. Remember, they laughed at Einstein, and now he has a field named after him. You can always display it as a "future project" at events. Without air it's not a safety problem |
#15
