Go to Post Since this thread doesn't seem to have quite enough numbers yet, here are some more. - William Frost [more]
Unread 16-02-2015, 23:00
xmaskid96's Avatar
xmaskid96 xmaskid96 is offline
AKA: Nikhil Patel
FRC #4701 (Team W.I.R.E. (Warriors in Robotics Education))
xmaskid96 is an unknown quantity at this point
pic: Team 4701 presents Skittles!
Unread 17-02-2015, 13:52
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
Re: pic: Team 4701 presents Skittles!
Looks good guys !
How does your robot collect totes at the chute ?
Do you remove the fork extensions to get shorter forks ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 17-02-2015, 21:17
xmaskid96's Avatar
AKA: Nikhil Patel
Originally Posted by lynca View Post
Looks good guys !
Thanks!!
To collect the totes at the chute door, it requires a little coordination by the drivers, but it has been practiced. The plan is to set up two totes, then grab one back up and let another one fall ontop, place the held tote ontop, and repeat the process until a stack of 4 is made....This isn't our main strategy but it can be done if needed.
The arms detach completely off. They are stored on the back frame of the robot with studs and wing nuts. The same system is used to attach the arms to its driving mode. It has proven to be an easy transition that can be done within 60 seconds.
