Go to Post Science and Technology is like the tide in the ocean, it raises all ships together, whether they're an engineering ship or a manual labor ship. - Doc Wu [more]
Unread 20-02-2015, 00:04
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
pic: Panthrobotics Presents Ascendance
Unread 20-02-2015, 00:06
MysterE's Avatar
FRC Team #3337
AKA: Coach Eiland
Release: Panthrobotics Presents Ascendance
I wanted to mention real quick the URL for PlastiDip. We found some amazing paints from them that really made for some cool robot designs.
https://www.dipyourcar.com/PlastiDip/
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 20-02-2015, 08:10
abross's Avatar
abross abross is offline
FRC #5113 (Combustible Lemons)
abross is on a distinguished road
Re: pic: Panthrobotics Presents Ascendance
Very cool robot design. I too am a huge fan of plastidip. This is the first time I've noticed a team using it.
2009-2010: Storm Robotics 2729 (Student)
2014-****: Combustible Lemons 5113 (Lead Mentor)
Unread 22-02-2015, 05:45
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
FRC #4587 (Jersey Voltage)
Clayton Summerall is on a distinguished road
Is there a drop in the omni wheels?
Unread 22-02-2015, 13:23
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If I recall correctly, grasshopper is a variant of butterfly/octanum. Usually only the omnis or only the traction wheels contact the floor at any given time.
Unread 22-02-2015, 13:43
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
What's the pitch between the hooks (though ledges or mantles might be a better description)? Obviously a bit larger than 12", but probably not too much larger to speed up disengaging from a stack of totes.
Hmmm.. If you run the conveyors up so high that the hooks pull out of the way, I suppose you could still make stacks taller than 4 totes if those shelves are short enough to feet between the extended stacking tabs on the side of the totes. That would certainly make for a secure carry of single totes on each hook, as well.
See you at Bayou!
Unread 22-02-2015, 14:27
The way grasshopper works is that there is a drop in the omni wheels and uses the drop/tilt when actuating the traction wheels to raise the omni wheels off the ground.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 23-02-2015, 00:14
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Then I recalled correctly.
