Go to Post I can't really think of a bad FIRST experience, really, I can't. - Joshua May [more]
Unread 25-02-2015, 23:53
Tuxedolarry's Avatar
Tuxedolarry Tuxedolarry is offline
Lead of Design/Electrical
AKA: Noah J.
FRC #0706 (CyberHawks)
Team Role: Electrical
Tuxedolarry is an unknown quantity at this point
pic: 706's Electronics Board Top View
Unread 25-02-2015, 23:56
olapmonkey's Avatar
olapmonkey olapmonkey is offline
AKA: Mr J
FRC #0706 (Cyberhawks)
Rookie Year: 2015
olapmonkey is an unknown quantity at this point
Re: pic: 706's Electronics Board Top View
Sweet and clean board layout...with the fuchsia glow...it's just plain insane (in a good way).
Unread 26-02-2015, 08:07
philso philso is offline
FRC #2587
That is a nice layout and a very clean design for the rest of the robot.
What are you using for the "link belt" on the front lift for the totes?
For your rear RC lift, you seem to be using plastic rollers at the top and ball bearings at the bottom, at least on one side. What advantage does this have?
Unread 26-02-2015, 09:27
Bruceb's Avatar
Bruceb Bruceb is offline
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
we were having problems with the steel flange bearings heavily wearing the sides of the aluminum tube so we switched to the plastic rollers over bearings to eliminate this.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 26-02-2015, 10:14
AKA: Noah J.
As for the belt, we are using a modular conveyor system that one of our sponsors sells.
http://www.dornerconveyors.com/Produ...SmartFlex.aspx
Each link is made of plastic and is able to pivot slightly in its track to go around corners (or give some play when picking up totes!) The whole belt then rides inside of an aluminum extrusion. To mount the hooks to the belt we took off a few links and drilled holes through back of the link for countersunk screws. It turned out pretty well!
