Go to Post P.S. While I doubt Karthik's "Delgado" jersey would go for $500,000... it would be much cooler to see Carlos Degado wearing a "Kanagasabapathy" jersey. THAT I might pay for! - dtengineering [more]
Unread 02-03-2015, 00:17
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: 6X multiplier?
Originally Posted by wesbass23 View Post
Would this possibly not count as scored because the bins could technically be supporting each other?
From the Q&A:
Q55
Q.Can more than one recycle bin be scored on the same stack if they are both fully supported by the tote stack?
A.Yes, per Section 3.1.2.3, a RECYCLING CONTAINER is scored if it is fully supported by only scored Gray TOTES.
Q418
Q.We are seeking clarification for "A RECYCLING CONTAINER is scored if it is fully supported by only scored Gray TOTES." A sideways RECYCLING CONTAINER can be scored where it rolls and contacts another scored RECYCLING CONTAINER on an adjacent stack. The weight of both RECYCLING CONTAINERS are fully supported by the scored Gray TOTES beneath them, but there is significant horizontal contact between the RECYCLING CONTAINERS. Are both RECYCLING CONTAINERS considered scored?
A.If the weight of both RECYCLING CONTAINERS is fully supported by only scored Grey TOTES beneath them, both RECYCLING CONTAINERS would be considered scored. Contact between RECYCLING CONTAINERS that does not support any of their weight will not prevent them from scoring.
