Go to Post It all depends on which box your trying to think outside. - ItsPat [more]
Unread 04-03-2015, 00:00
MrForbes MrForbes is offline
Re: pic: Poly-carbonate Gearbox Plate
Can you fit an Igus type plastic bushing in there? or a bronze bushing?
And yeah, all those irregular holes look like a waste of machining time, but then I'm a naturally lazy person.
Unread 04-03-2015, 00:46
You can't afford to use the kind of aggressive lightening patterns in polycarb that you can in aluminum, particularly for gearboxes. Polycarbonate just isn't rigid enough. I would not pocket the gearbox at all, and maybe add more counterbores standoffs to give you rigidity. All of the rules for pocketing aluminum gearboxes just don't apply here.
To answer your question, could you run a shaft in polycarb without a bushing... Maybe, but probably not at 1200 RPM. You could easily heat the polycarbonate up to its glass transition point wih aggressive driving and things would get ugly fast. Even if it works though, your efficiency will tank beyond the point where it's worth it. An encoder is a terrible reason to throw out ball bearings...
Unread 04-03-2015, 00:47
Munchskull's Avatar
Munchskull Munchskull is offline
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
I definitely can/will/did remove the lightening holes. I can fit a bushing if I have to, I just wanted to check before if got them.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 04-03-2015, 00:55
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
I would tend to agree with Chris, that I wouldn't even go as far as to swap from a ball bearing in an application as crucial as a drivetrain. Just use a mount plate like this, you'll be much better off.
Unread 04-03-2015, 01:06
Munchskull's Avatar
I thought as much. My belief has been to design dangerously but build safely. I will see if a bronze bushing will work. We have two extra gear box's that would use this plate, I think that I will make and install one with a bushing and run the gearbox for a good two hours on full checking in at ten minute intervals (don't worry someone will be in the room) and take picture for records. while it may never go on a robot it would be a great learning experience for designing with plastic.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 04-03-2015, 11:34
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
For that to be a realistic test, the gearbox must be put under loads similar to what it will see on an frc robot. Testing it as you described, with no load, will not expose any potential problems fully
(2015-?): 973
(2012-2015): 955
