Go to Post (You know you're overdosed on FIRST) when watching regional web-casts takes precedent over Saturday morning cartoons. - Hawiian Cadder [more]
Unread 10-03-2015, 13:35
Kevin Sheridan's Avatar
Kevin Sheridan Kevin Sheridan is offline
Kevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond repute
Re: pic: 330 placing three cans up high
Originally Posted by MrForbes View Post
I noticed Poofs putting two containers on a stack in practice in CVR, and didn't see it again...not sure what's up with the scoring of more than one container per stack. The rule above seems to indicate it's scored by level, so as long as it's supported by gray totes, all the containers count, no matter how many stacks. And I didn't read the other thread that probably discussed this, because I was "busy".
Explanations and rule or Q&A citations welcome...
Q. Can more than one recycle bin be scored on the same stack if they are both fully supported by the tote stack?
2015-01-08 by FRC0237
A. Yes, per Section 3.1.2.3, a RECYCLING CONTAINER is scored if it is fully supported by only scored Gray TOTES.
2015-01-09
Published by GDC
https://frc-qa.usfirst.org/Question/...the-tote-stack
