Go to Post I always thought a trained bio mechanical monkey wrapped in aluminum foil would be the best robot, but every year my team says "No Pete, go sit down." - BuddyB309 [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 16-03-2015, 00:45
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: KING TeC 2169 Lift Gear
Originally Posted by Adrian Clark View Post
The broken gear: 7075 Al ~70ksi yield strength
Common steel gear: ~40ksi yeild strength
You can't fix this problem by replacing the gear. The pinion is overloaded and the best fix is a redesign that reduces load.
-Adrian
Edit: I went on a gear strength rant a while back, it could help you.
http://www.chiefdelphi.com/forums/sh...4&postcount=15
Adrian
I agree they should fix the design to not load such a small gear/use on final reduction. But also I believe all the steel gears by VEX PRO are 4140 steel which should have a yield at 100ksi or more.
R.C.
MadTown Robotics Team 1323
Unread 16-03-2015, 05:59
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
We also were concerned about this problem - we didn't want to run the motors against the hard stop at the top and bottom of the elevator travel.
We use a pot to control travel of the elevator. Since it's possible for the pot to come loose and change value we put a second pot on the other side and compare the two to make sure they agree. We also added a light sensor that checks the position of the elevator in the middle of its travel as another check. (We've never made a robot with an elevator before so we were a bit cautious.)
If the elevator comes down on top of a tote it's possible for the elevator to tip the robot over. (This happened at our week 0 event when the HP tried to add a 7th tote and the co-driver tried to block it by dropping the elevator.) To stop the robot from tipping over, the software/electrical team added a sensor that detects when the front of the robot lifts off the ground. (I'm not sure what sensor they added.)
Unread 16-03-2015, 09:48
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
A quick question, what material is the gear that this gear was meshed to? You probably want to have them be the same material, that has given us issues in the past. That doesn't mean don't change the gear material, but if you have to then change both gears.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 16-03-2015, 10:23
Aren_Hill's Avatar
Build Nifty Things
Adrian
^This is correct, all of our steel gears are hardened 4140, a fair amount stronger than the typical 1018 steel gear.
-Aren
A guy who likes robots.
Unread 17-03-2015, 14:18
FRC #1678 (Citrus Circuits)
RC, Aren,
First off, I'd like to apologize for posting false information. I clearly did not have standard gear alloys in mind when I posted that. To correct myself: a common steel gear would be around 50-60ksi.
I'm always the first one to jump up and quell the assumption that switching to steel from aluminum isn't necessarily a strength gain. The reason being that your average steel gear, say 4140, has a lower yield than 7075 Al. This is because a lot of steel gears are sold in an annealed state.
I was not aware that vex hardens their gears. Now that I know, I'm even more in awe of the quality and value of products company's like vex are selling.
On a side note, to the vex pro squad: under the CIM gear section on your website at the top of the page the steel gears are said to be made from 5150. However, lower down on the page it says they are 4140. Also, I don't believe it's mentioned anywhere that the gears are hardened. I would personally suggest that on the website you include the fact that you harden the gears. For me, the lack of that information would be the deciding factor in whether or not I buy a steel pinon. I mean, they're listed as 5051 (yield of ~50ksi iirc) when in actuality they're twice the strength.
tl;dr, disregard my previous post. I was incorrect that steel pinions were weaker that their 7075 counterpart. At least for vex pro products.
-Adrian
Edit: Wanted to share a little snipit of wisdom I recently leaned regarding cim pinions. Vex sells cim output shafts for VPs. Be mindful when using a cim pinion on a VP, you're putting a significantly higher load on the pinion by running it through a reduction and if not accounted for it could completely ruin your performance at competition.
