Go to Post I don't have enough vacation time for them to start allowing video replay. - TJP123 [more]
Unread 23-03-2015, 16:00
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
pic: Team 4587: Ratman and Bobin
Unread 23-03-2015, 16:26
Cash4587's Avatar
AKA: Cooper Cash
Re: pic: Team 4587: Ratman and Bobin
Ratman Specs:
-Drivetrain
8wd with 4" omni wheels
Chain driven
Single speed
One cim per side in WCP SS Gearboxes with 6.111 overall reduction
Theoretical speed of 14.26 fps
Navx Gyro control
Single encoder for distance measurement
-Intake
2 wheel roller intake
50:1 versaplanetary with a bag motor
Uses sure grip drive rollers from Mcmaster carr to achieve maximum grip on cans and totes
Belt driven wheels using 36t pulleys and 9mm vex pro belts
piston actuated to provide maximum clamping force to pull a stack of 6 totes out of Bobin
-Can Lift
78" tall lift to have the ability to top off any stack
powered by a 10:1 versaplanetary mini Cim gearbox providing maximum speed up and down
custom chain driven carriage that slides smoothly on a 2x1 1/16th" tube
pitchfork that cradles the can in the fallen over position
piston that raises and lowers the pitchfork to allow easy intake of can and a tilted position to not fall out
Encoder and limit switch used to aid in PID control
Bobin:
Feeder station stacker that can stack totes while Ratman is retrieving the can
chain driven carriage powered by a 25:1 Mini Cim versaplanetary gearbox
passive flap door powered by surgical tubing to prevent the first tote from flipping over or going too far into the field
passive tote clips using surgical tubing and piano hinge
ability for any robot with a powered roller intake to take out a stack of totes out at any time
PID controlled with encoder and limit switch
Tether:
10ga wire for the motor
Ethernet cable for sensors
25ft in length
wrapped in nylon wire loom to resist abrasion
Best of all: It is all painted in Camaro yellow and Camaro black
Feel free to ask if you have any questions. I may have forgotten to include some things.
Unread 24-03-2015, 02:17
MattC9's Avatar
MattC9 MattC9 is offline
The fact that any other robot, with a roller intake, can take from Bobin is awesome. Well done guys.
Unread 29-03-2015, 06:01
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
Clayton Summerall is on a distinguished road
Talking Re: pic: Team 4587: Ratman and Bobin
Such a Nice looking Robot!!!
Good luck at Lone Star!
Unread 29-03-2015, 10:40
Ichlieberoboter's Avatar
Ichlieberoboter Ichlieberoboter is offline
Awards and Programming
AKA: Maria Valentini
FRC #2499 (Industrial Revolution)
Ichlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud of
Looks really cool! Reminds me a bit of another #teamtether robot...
Team 2499-Industrial Revolution
2015 Lake Superior Regional Judges Award
Head Programmer Chairman's Award Presenter Awards Submitter Electrical Team Website Designer Strategy Team
Unread 14-04-2015, 19:24
Illuminati Illuminati is offline
Junior Member
FRC #0068
Illuminati is an unknown quantity at this point
