pic: Team 4587: Ratman and Bobin
Re: pic: Team 4587: Ratman and Bobin
Ratman Specs:
-Drivetrain 8wd with 4" omni wheels Chain driven Single speed One cim per side in WCP SS Gearboxes with 6.111 overall reduction Theoretical speed of 14.26 fps Navx Gyro control Single encoder for distance measurement -Intake 2 wheel roller intake 50:1 versaplanetary with a bag motor Uses sure grip drive rollers from Mcmaster carr to achieve maximum grip on cans and totes Belt driven wheels using 36t pulleys and 9mm vex pro belts piston actuated to provide maximum clamping force to pull a stack of 6 totes out of Bobin -Can Lift 78" tall lift to have the ability to top off any stack powered by a 10:1 versaplanetary mini Cim gearbox providing maximum speed up and down custom chain driven carriage that slides smoothly on a 2x1 1/16th" tube pitchfork that cradles the can in the fallen over position piston that raises and lowers the pitchfork to allow easy intake of can and a tilted position to not fall out Encoder and limit switch used to aid in PID control Bobin: Feeder station stacker that can stack totes while Ratman is retrieving the can chain driven carriage powered by a 25:1 Mini Cim versaplanetary gearbox passive flap door powered by surgical tubing to prevent the first tote from flipping over or going too far into the field passive tote clips using surgical tubing and piano hinge ability for any robot with a powered roller intake to take out a stack of totes out at any time PID controlled with encoder and limit switch Tether: 10ga wire for the motor Ethernet cable for sensors 25ft in length wrapped in nylon wire loom to resist abrasion Best of all: It is all painted in Camaro yellow and Camaro black Feel free to ask if you have any questions. I may have forgotten to include some things. |
The fact that any other robot, with a roller intake, can take from Bobin is awesome. Well done guys.
Such a Nice looking Robot!!!
Good luck at Lone Star! ![]() |
Looks really cool! Reminds me a bit of another #teamtether robot...
