Go to Post I was surprised how easily Mike hoisted me off the ground. I'm nearly 250 pounds and he lifted me up like I was a soccer ball! :ahh: - Koko Ed [more]
Unread 06-04-2015, 12:40
kpie3692 kpie3692 is offline
FRC #3692
kpie3692 will become famous soon enoughkpie3692 will become famous soon enough
Re: pic: 3692's PDP after catching on fire at Queen City
Originally Posted by JamesCH95 View Post
...or a faulty termination.
...or a jammed breaker.
...or a motor controller fault.
...or a wire with some nicked strands from stripping.
etc.
My point is that unless you have some very specific and compelling evidence to rule out everything else (or confirm it was a mfg defect) I don't think that you should be so quick to throw CTE under the bus for this!
For example, if a few strands of one wire contacted the terminal of another wire it would take much less than 40A to heat up those strands enough to light some plastic on fire.
You're right, I shouldn't have been so quick to say it was an mfg defect.
