Thread Tools |
Rating:
Display Modes |
Re: pic: In-Line Pneumatic Fittings
http://www.automationdirect.com/stat...linegauges.pdf |
I have used these too, they are fantastic. Very happy they are a bit orange to o.
Looks like a fantastic part, and the sort of thing I hope we see more of (if it's legal). My advice would be to file it away for future reference, and wait to see if it's determined to be legal in the future. I hope it is, I want to use it on my robot. Insert standard disclaimer here about all previous year's rules not applying in all future years ![]() |
I assume that this is a relieving regulator, is that correct? If it isn't, I'm going to have to concur on the "maybe shouldn't have passed inspection" crowd. If it is, I think I'll pass the info on to my team...
Does this even pass rule 66 G?
Is it worth using these type of fittings when the brass fittings do a good job in serving as a heatsink for the compressors?
#10
So yes, if both components are legal then it's worth it to us (and many others) |
#11
It depends entirely on how much air you need. If you're using air solely to shift gears, probably not. If every function other than drive is pneumatic, quite possibly. We blew out several hoses (with a crack like a .22) during practice for rebound rumble. We had a pneumatic climber, but we didn't even have the climber attached yet. We were just making adjustments to the Frisbee primer that required depressurizing the system. In filling up our (seven?) plastic tanks, we blew out the hose at the end nearest the compressor. The large quantity of air depressurizing through the rupture cooled the tubing back down, so it took us several swaps to figure out that it wasn't just defective tubing. This was followed by closer monitoring to figure out the actual cause. Our solution was to relocate as much of the brass as possible to before the first piece of tubing, and continued monitoring for swollen tubing.
#12
On the practice bot, we use either a Thomas 215 or another who's name escapes me. Also, if your tubing was blowing out from only filling 7 (assuming black Clippard?) tanks you may want to re-evaluate both the fittings and tubing you are using. I know in our case, we have melted the O-rings within the 1/4 pneumatic quick connects (but this is after 30+ minutes of running and the crappy FIRST Choice connectors) Or add a fan. We use Freelin-Wade tubing, and SMC pneumatic fittings. Last edited by Dunngeon : 28-04-2015 at 00:01. Reason: grammar |
#13
Mounting a KOP computer cooling fan blowing on the compressor head allows the small compressor to be run at 100 percent duty cycle. We have done all day demos with our 2014 bot, with pneumatic catapult, and the compressor barely gets warm. This year our air consumption is less, so we left off the fan. Just filling two tanks gets it scalding hot.
#14
We made the corrections during practice and did not have the problem during competition. For UA, our understanding (probably incorrect, as I recently learned from another thread) was that relieving the air pressure between matches was mandatory. As a result, we stressed the system more during competition than we did during pre-climb practices when we were actuating a single 3/4" diameter cylinder with about a 6" stroke.
#15
Just as a note: If I'm not mistaken, these would be located well downstream from the compressor, say on the other side of the storage tanks. This isn't the pressure relief valve, it's a regulator. The PRV has a specific part number, and must be hard-mounted.
