Go to Post All I ask is that you stay with FIRST. It's a great place to be - Wayne Doenges [more]
Unread 26-04-2015, 23:50
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: pic: In-Line Pneumatic Fittings
Originally Posted by Jeff Pahl View Post
And the spec sheet only says that it regulates from 15-120 PSI. Based on that, it does not meet the 125 PSI requirement in the 2015 rules. I know it passed inspection this year, but that does not mean it should have...
Looks like a fantastic part, and the sort of thing I hope we see more of (if it's legal). My advice would be to file it away for future reference, and wait to see if it's determined to be legal in the future. I hope it is, I want to use it on my robot.
Insert standard disclaimer here about all previous year's rules not applying in all future years
I think I'm going to send an email to them, and ask them to add the maximum pressure rating to the spec sheet. I'm sure its higher then 120psi, since it can regulate down to that. There's a similar one on McMaster that should work, and it says 150 maximum, so it would be legal. 8844K11
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 27-04-2015, 00:13
EricH EricH is offline
I assume that this is a relieving regulator, is that correct? If it isn't, I'm going to have to concur on the "maybe shouldn't have passed inspection" crowd. If it is, I think I'll pass the info on to my team...
Unread 27-04-2015, 00:19
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Does this even pass rule 66 G?
R66 The only pneumatic system items permitted on 2015 FRC ROBOTS include the items listed below.
A. Items available in the KOP (except as noted in I),
B. Pneumatic pressure vent plug valves functionally equivalent to those provided in the KOP,
C. Solenoid valves with a maximum 1/8 in. NPT port diameter,
D. Solenoid valves that are rated for a maximum rated pressure that is less than 125 psi rating mandated above are permitted,
however if employed, an additional pressure relief valve must be added to the low pressure side of the main regulator. The
additional relief valve must be set to a lower pressure than the maximum pressure rating for the solenoid valve,
E. Additional pneumatic tubing, with a maximum 0.160 in. inside diameter, functionally equivalent to that provided in the KOP,
F. Pressure transducers, pressure gauges, passive flow control valves (specifically “needle valves”), manifolds, and
connecting fittings,
G. Pressure regulators with a maximum outlet pressure of no more than 60 psi,
H. Pneumatic cylinders,
I. Pneumatic storage tanks (with the exception of White Clippard tanks P/N: AVT-PP-41), and
J. Compressors compliant with R68.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 27-04-2015, 01:27
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Is it worth using these type of fittings when the brass fittings do a good job in serving as a heatsink for the compressors?
Unread 27-04-2015, 01:40
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
It's not that they serve as a heat sink for the compressor, but that they dissipate heat before it melts the tubing. In any case, weightloss anywhere on the robot is very good, and you won't melt tubing on a competition bot because of the short run times
So yes, if both components are legal then it's worth it to us (and many others)
(2015-?): 973
(2012-2015): 955
Unread 27-04-2015, 18:01
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
It depends entirely on how much air you need. If you're using air solely to shift gears, probably not. If every function other than drive is pneumatic, quite possibly. We blew out several hoses (with a crack like a .22) during practice for rebound rumble. We had a pneumatic climber, but we didn't even have the climber attached yet. We were just making adjustments to the Frisbee primer that required depressurizing the system. In filling up our (seven?) plastic tanks, we blew out the hose at the end nearest the compressor. The large quantity of air depressurizing through the rupture cooled the tubing back down, so it took us several swaps to figure out that it wasn't just defective tubing. This was followed by closer monitoring to figure out the actual cause. Our solution was to relocate as much of the brass as possible to before the first piece of tubing, and continued monitoring for swollen tubing.
Unread 27-04-2015, 23:17
Pumped
AKA: Ryan
Emphasis mine. I said Competition Bot. We use a different compressor that is rated for 100% duty on the practice bot, but use the VIAIR 90C on the competition bot for the obvious weight savings. Nearly our entire bot was pneumatic, and the 90C was capable to compressing for nearly 20 minutes straight before we ever had a blow out. (not that I recommend it)
On the practice bot, we use either a Thomas 215 or another who's name escapes me.
Also, if your tubing was blowing out from only filling 7 (assuming black Clippard?) tanks you may want to re-evaluate both the fittings and tubing you are using. I know in our case, we have melted the O-rings within the 1/4 pneumatic quick connects (but this is after 30+ minutes of running and the crappy FIRST Choice connectors)
Or add a fan.
We use Freelin-Wade tubing, and SMC pneumatic fittings.
(2015-?): 973
(2012-2015): 955
Unread 27-04-2015, 23:38
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Mounting a KOP computer cooling fan blowing on the compressor head allows the small compressor to be run at 100 percent duty cycle. We have done all day demos with our 2014 bot, with pneumatic catapult, and the compressor barely gets warm. This year our air consumption is less, so we left off the fan. Just filling two tanks gets it scalding hot.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 30-04-2015, 20:21
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
We made the corrections during practice and did not have the problem during competition. For UA, our understanding (probably incorrect, as I recently learned from another thread) was that relieving the air pressure between matches was mandatory. As a result, we stressed the system more during competition than we did during pre-climb practices when we were actuating a single 3/4" diameter cylinder with about a 6" stroke.
Unread 27-04-2015, 02:13
Just as a note: If I'm not mistaken, these would be located well downstream from the compressor, say on the other side of the storage tanks. This isn't the pressure relief valve, it's a regulator. The PRV has a specific part number, and must be hard-mounted.
Unread 27-04-2015, 02:19
Ah. I figured I missed something. Thanks!
Unread 27-04-2015, 01:37
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
The KOP regulators have the capability of regulating higher pressure than 60PSI if you set them to.
Unread 27-04-2015, 08:45
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
No.
Some manufactures offer optional outlet pressure ranges, but I do not see that on this cut sheet.
Should not have passed with >60 outlet pressure.
IMHO, not an inspector.
The sooner we get behind schedule, the more time we have to catch up.
Unread 27-04-2015, 09:35
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Hi Guys,
The max pressure rating for this device is 145 psi.
This is sold under the NITRA label so I can't share the original manufacturers data sheet with you.
I'll put in a request to get the NITRA spec sheet updated.
Comments on posts:
(Jeff Pahl - Been Long time! How ya doing!)
#7: "And the spec sheet only says that it regulates from 15-120 PSI." It regulates between those values - the max rating is 145.
#12: R66G - This really only applies to the primary regulator which HAS to be the KOP regulator (and is limited to 5-50psi). These should only be used DOWNSTREAM of that. Just like all the other regulators we typically use. Yes, I know the rules don't explicitly say that - we are talking to FIRST about the wording of that rule because it doesn't make any sense as stated...
#13 "Is it worth using these type of fittings ..." Oh yeah ... Space savings, weight savings, mount them anywhere, totally worth it. And again - these would not be used as the primary regulator right up next to the compressor.
This IS a PRV type regulator (relieves excess downstream pressure)
And while we are at it ...
The original post only shows two of the parts offered as inline. There are a bunch more folks need to be aware of:
Pressure Indicators: (PMU14A, PMU14G) Green and Orange - Has a little pop-up indicator that pops up when the system has 30+ psi in it. An awesome way to tell if the system is pressurized at a glance
Shut Off Valves - 2 and 3-way shut off valves - the 3-way valves relieve downstream pressure so you can shut off a subsystem and release pressure at the same time. Very handy. (HVU14-2, HVU14-3)
These are also available in lockable versions.
Quick Exhaust Valves - Want to speed up you pneumatics? This is a great way to do it. Routes exhaust air directly to atmosphere.
And of course, AutomationDirect has:
- FREE shipping on orders over $49.
- FAST Shipping - all items are in stock and ship same day via FedEx. Usually takes no more than 2 days. Fast shipping includes CANADA!
- $30 Coupon - was in your kit of parts to use on anything you want - I hope you used it!
Let us know if you have any questions about AutomationDirect Parts. Beast way to reach us: educational@automationdirect.com.
Either Chip McDaniel or myself (Rick Folea) will be happy to help you out.
Unread 27-04-2015, 09:53
rfolea's Avatar
AKA: Rick Folea
... Should have mentioned that all of these items are located here.
