Thread Tools |
Rating:
Display Modes |
Re: pic: In-Line Pneumatic Fittings
Hi Guys,
The max pressure rating for this device is 145 psi. This is sold under the NITRA label so I can't share the original manufacturers data sheet with you. I'll put in a request to get the NITRA spec sheet updated. Comments on posts: (Jeff Pahl - Been Long time! How ya doing!) #7: "And the spec sheet only says that it regulates from 15-120 PSI." It regulates between those values - the max rating is 145. #12: R66G - This really only applies to the primary regulator which HAS to be the KOP regulator (and is limited to 5-50psi). These should only be used DOWNSTREAM of that. Just like all the other regulators we typically use. Yes, I know the rules don't explicitly say that - we are talking to FIRST about the wording of that rule because it doesn't make any sense as stated... #13 "Is it worth using these type of fittings ..." Oh yeah ... Space savings, weight savings, mount them anywhere, totally worth it. And again - these would not be used as the primary regulator right up next to the compressor. This IS a PRV type regulator (relieves excess downstream pressure) And while we are at it ... The original post only shows two of the parts offered as inline. There are a bunch more folks need to be aware of: Pressure Indicators: (PMU14A, PMU14G) Green and Orange - Has a little pop-up indicator that pops up when the system has 30+ psi in it. An awesome way to tell if the system is pressurized at a glance Shut Off Valves - 2 and 3-way shut off valves - the 3-way valves relieve downstream pressure so you can shut off a subsystem and release pressure at the same time. Very handy. (HVU14-2, HVU14-3) These are also available in lockable versions. Quick Exhaust Valves - Want to speed up you pneumatics? This is a great way to do it. Routes exhaust air directly to atmosphere. And of course, AutomationDirect has: - FREE shipping on orders over $49. - FAST Shipping - all items are in stock and ship same day via FedEx. Usually takes no more than 2 days. Fast shipping includes CANADA! - $30 Coupon - was in your kit of parts to use on anything you want - I hope you used it! Let us know if you have any questions about AutomationDirect Parts. Beast way to reach us: educational@automationdirect.com. Either Chip McDaniel or myself (Rick Folea) will be happy to help you out. Last edited by rfolea : 27-04-2015 at 09:53. |
Mind you, I'd love if they were legal for the obvious speed increases. So if you're petitioning the GDC to update the regulator part of R66, you might want to add that as well. |
A good question that has never been adequately answered, especially given the fact that it's legal to just not put a fitting in one end of a dual-stroke cylinder and vent directly to atmosphere that way.
The problem with this argument is the QUICK exhaust valves actually make the system SAFER in that they GUARANTEE the system won't be pressurized. Yes, we are working on the wording of that one too ... Sometimes common sense HAS to win ... BTW - all the solenoid valves folks use that have a center closed position are ALSO illegal under this rule (they can keep a system pressurized after venting), but no one seems to notice that ... |
In other news, the pneumatics rules are kind of arcane and vague and could really use some revising to better clarify and enforce whatever the GDC's intent behind them is. There's some hint of an intent to limit actuator speeds and unintentional overpressure from external loads on cylinders, but it'd be better if they spelled that out up front. |
R66B requires pressure plug vent valves be functionally equivalent to the (2-way) KOP valves, so I am not sure 3-way valves would be meet that requirement (probably should ask next years Q&A, or try to get the rule changed for next year). I agree they would be useful (especially this year for removing cylinders to fit into transport configuration). |
