Go to Post I'm wondering just what you think the people who DID set this system up actually do for a living instead? Sheep farmers? - DonRotolo [more]
Unread 27-04-2015, 20:13
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
pic: Championship Upgrade
Unread 27-04-2015, 20:14
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: pic: Championship Upgrade
What is it used for? If i may ask
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 27-04-2015, 20:30
Mark Holschuh's Avatar
Mark Holschuh Mark Holschuh is offline
FRC #2194 (Fondy Fire)
Mark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud of
That is one nice render! My memory is that this was used to join the ends of the lift chain and adjust out the slack in the chain.
"The true sign of intelligence is not knowledge but imagination."
-- Albert Einstein,
"The ultimate test of man's conscience may be his willingness to sacrifice something today for future generations whose words of thanks will not be heard."
- - William Proxmire
Unread 27-04-2015, 20:49
Yes - it's to tighten the chain. The problem was in the initial CAD layout we left 4.5" for it but didn't have a particular design in mind. Just seemed like 4.5" was enough. Toward the end of the build season we added a conventional turnbuckle style with eye bolts. This came out 5.5" long and the elevator wouldn't travel quite far enough. We had to jockey the bot around when totes were coming down the chute.
After week six, our lead mechanical mentor came up with this design to get the 1" of travel back. Now the totes fall out of the chute into the bot just as sweet as can be. Our OPR went from 85 to 104.
The lesson is, saving a couple of seconds many times in a match ends up being a big deal.
Unread 27-04-2015, 22:42
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
I remember at the scrimmage you guys telling me that if we found a smaller way to tension chain other than a turn buckle to let you guys know. I did not realize it was a big issue. I will have to remember this for future years...or just use belts
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 28-04-2015, 07:24
"big" depends on your point of view - 85 was a decent OPR to start with. Being able to push it up to the 13th highest in FRC was pretty cool.
Unread 28-04-2015, 10:02
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Very nice! I happened to find these from Misumi while stumbling through CD a few months ago, and they worked out well. The end caps are the opposite of yours, and were a bit tricky to get together using the Dark Soul #25 chain tool...but once together, held up quite nicely. They were pretty cheap too.
FRC78: 2010-Present
FRC121: 2002-2009
