Go to Post Got Valentine's day present from wife before leaving for work. Non-contact IR thermometer, two unscuffed pairs of safety glasses for competitions, bag of York peppermint patties. She understands me. - Greg Young [more]
Unread 08-05-2015, 13:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Small CIM in wheel swerve
Originally Posted by Bryce2471 View Post
i'm not sure about lighter, but I thought it would be a shame to put such a tall gearbox on such a short swerve module.
If you used a worm gear for steering, it seems to me that you could orient both motors horizontally and get the module height down to the wheel diameter. You'd also save some weight on a second gear stage at a bit of loss of steering efficiency. You'd need slip rings for the drive motor since you couldn't run the wire out through the rotation hub, which might eat up the weight savings.
Also, what is the light colored gear to the lower right of the main rendering? I don't see what else it engages, and I also don't see it in the reflection.
