Go to Post That little 18 amp-hour battery has a really hard life in a FIRST robot. - eugenebrooks [more]
Unread 08-05-2015, 15:33
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Small CIM in wheel swerve
Originally Posted by Skywalkar View Post
From the looks of the reflection, I would say that it's paired with another pinion underneath the bottom support plate via a live axle, which in turn is what engages the great big ring gear that goes around the perimeter of the module.
That makes for a 3-stage reduction in total, so I am inclined to agree that a worm gear would be a viable option here.
Thanks, Skywalkar - I see it now. The reflection plane must be tilted down as it approaches the viewpoint (or the vertical on the module is tilted away at the top). I thought it strange that the dark gray gear did not engage with anything except to pass through to the yellow gear below the lower plate.
