Go to Post The Pet Rock was very original, but not necessarily a great thing. - IKE [more]
Unread 09-05-2015, 13:12
Re: pic: Small CIM in wheel swerve
On 696, we had a large 84T 20DP steering gear, and a 1:3.5 ratio between that and our MA3 absolute encoder. That is, the steering encoder would pass through 3.5 rotations for every one rotation of the swerve module. We had to physically set the wheels pointing straight at the start of each match (which is probably good practice anyhow), and there was a good bit of math and code involved, but we were able to very reliably track the position of our wheels at all times, resulting in fine control and operation.
Was it easy or friendly to do it this way? No. Is it possible? Yes. Would we run anything other than a 1:1 ratio to an absolute encoder again? Maybe not. It's kind of a pain. We likely will look into using a zeroing sensor and incremental encoder next time if we cannot maintain a 1:1 ratio with an absolute encoder.
