Go to Post You can't simply bring another 100 teams into FIRST and have them all asking Andy Baker questions. - Rich Kressly [more]
  #42   Spotlight this post!
Unread 09-05-2015, 15:25
Re: pic: Small CIM in wheel swerve
If your sample time is fast and stable enough that the encoder could never turn 180 degrees from one sample to the next, then "all ya gotta do" at each sample is assume the encoder turned through the shortest angle, and keep track of zero crossings.
I think that's essentially what our programmer did, although the libraries involved had some glitches that presented many headaches.
For those of you discussing "drift" with incremental encoders, are you referring to an accumulation of lost counts? Does this happen when the direction of steering reverses, and is this accumulation of lost counts biased toward one direction? Would the solution to have something like a hall effect sensor for zeroing, and reset the count every time you cross it?
