Go to Post When is comes down to it, remember what FIRST is really about, it is about those students and helping to inspire them - E3 Robotics Ctr [more]
Unread 11-05-2015, 00:30
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Small CIM in wheel swerve
Originally Posted by Dunngeon View Post
Which slip ring would you use? Mercotac's are banned.
I was thinking of a custom solution when I suggested a module no taller than the wheel diameter. A quadrature encoder or a CAN controller wired in the traditional method would require 6 wires. Is it possible to make a CAN talon work with only two control wires that branch a bit away from the talon? If so, you could reduce the connection to four wires, if you could figure out a place to park the talon on the far side of the sliprings with the motor, gearbox, encoder, and wheel.
