Go to Post Making a part look pretty even after it is functionaly done can be a very good thing, espically when the part gets cut from the bot and you get to keep it as a trophey. Take pride in your work. - Andy A. [more]
Unread 16-05-2015, 02:05
Re: pic: Offseason Gearbox
Wait really? I was told I had to put all the radii in manually even for a CNC.
I've been lied to... lol.
You generally want to design the pocket radii some amount larger than the radius of the tool you intend to machine it with. This is to prevent the tool from encountering a sudden and peaking chip load when it gets into the tight corner. It needs some room to still move in the corner, so it isn't contacting all around at the same time.
